AlbqRadio
anbody know who owns the streaming feed for Abq Radio police and fire?
Yes why???
Hey guys,
Thanks for the feedback.
First, the audio is going through a MaCom Radio and the output is very hot. Because of that, I must use an attenuation cable and it seems to over-attenuate some (ok, alot, it actually burned out two attenuation cables). I have the radio and PC line input at full volume.
Second, I recently upgraded to Windows 7. Since then, the audio appears to be even lower than before. To add to that, the new version of scanner cast keeps throwing errors and disconnecting, a problem I did not have on the earlier version.
I plan to mess around with the feed on my weekend, but I really don't have many options as the volume is already at full on the radio and the PC. I am going to do some testing again with the headphone jack, but if I remember correctly, that didn't really help before.
Thanks for your patience.
Right now, I am running a slightly different setup. It appears to sound better, just a little "tinny" from time to time. I will let this setup run for awhile, let me know if there are anymore issues by replying here.
Thank you.
You nailed it it sounds better than ever!!
