AC to DC converter - which to get ?
mbnv992
AZ
So, I’d like to have my Motorola Visar set up so it’s on all the time at home. It’s already on a battery eliminator hooked up to this power converter so I can plug it in at home. Only issue is - not sure what model to get. This one is only good for 2 Amps or 12 volts. I order it and when I hit the PTT I get a loud humming noise over the air so I’d assume this one isn’t strong enough to handle 4 watts of transmit power of the Visar.
There’s another model that puts out 12 Volts and 5 amps should I order that one instead ? Don’t feel like burning the house down or blowing up the Visar with this smaller one.
mbnv992
AZ
On a side note - I took the battery eliminator ( and the Visar ) and hooked it up to my car and it was fine. No humming noise whatsoever. So my guess is this converter at home doesn’t have enough power to transmit with.
2 amps should be plenty to run the radio.
I think the issue you are having is a poorly filtered power supply. Sounds like the buzzing is 60 cycle crap from the power supply.
Finding a suitable one may be a challenge. Normally I'd recommend a larger power supply designed for communications use, but that's going to be more expensive than what you have now.
ramal121
Lots and lots of watts
Calif Whine Country
The radio shouldn't draw more than an 1 to 1 1/2 amps on transmit so it should be OK with what you have. If however if it is of poor design then yes you may be pushing its limit to regulate properly.
Also consider that your RF energy on transmit may be induced back into the power supply causing it to go unstable. It is what to expect with a POC from the PRC. Ditch it and get another with 2 amp or better capabilities. Good luck.
mbnv992
AZ
Thanks guys
I’m gonna go with this one and see how it does.
It can handle a much bigger load ( that’s what she said ) and hopefully will cause the static to go away as well.
The battery eliminator works great hooked up to the car so it’s not that. I shall report back here with my findings. Thanks again !
mbnv992
AZ
Followup to this post - purchased the 5AMP / 60watt model above and bingo ! Hum went away ! Seems like the smaller 2AMP wall plug wasn’t enough juice.
