ka3jjz
Wiki Admin Emeritus
There seems to be some detail missing - or wrong - in the wiki that describes this procedure. Item 3 reads:
Press in (and hold) the function knob for about 5 seconds until the [what is this - it's missing] IS FLASHING IN THE UPPER LEFT OF THE DISPLAY. Quickly press the volume knob ONCE. Note if the "F" stops flashing before you press the Vol Control start this step over.
I assume it's a 'F'? And instead of the 'Volume control' should you press the function knob once, since that's the way the volume is adjusted?
I had turned my Analog AGC on, and digital AGC off, but can't seem to get this procedure to work.
73 and TIA Mike
[edit] The procedure is outlined here...
http://wiki.radioreference.com/index.php/Uniden_Digital_AGC_Tweak_Procedures
73 and TIA Mike
