Accessory Jack Pin Out (Motorola M-214 5 Pin)
I bought this Motorola Amplified Speaker at a Recent Ham-Com. Well I seem to misplaced the Color combo vs. pin to Hook it up sheet that was provided.
The Radio is a 5-Pin Accessory Jack, Motorola M-214/216, The Speaker harness has 4 colors, Red and Black (Hot and Ground) Blue and Shield (Speaker) So from LEFT to RIGHT what color goes where???
DPapay
Morris County, N.J.
accessory plug
pin 1 is ext speaker neg, shield
pin 4 is ext speaker pos, blue wire
pin 1 is closer to the edge of the chassis.
red and black are obvious.
And which pins are RED & BLACK (Poss/Neg) on? The Jack IS NOT marked. Thanks though, This helps.
DPapay
Morris County, N.J.
ground the black to the same spot as the main power black, hook the red to the ignition wire, if used, or to the red main power wire if you are using that as ignition. if you are using as a base, just hook both to the main power wires.
