Accessory plug on tk-840
N4KVE
PALM BEACH, FLORIDA
I just picked up a nice TK-840 & there is a wiring harness exiting the radio under the power cord. It has a 15 pin connecter [3 rows, 5 pins each] & the harness connects to 3 or 4 factory sockets in the radio, as well as the speaker wire. The radio works fine without connecting this plug to anything, & seems to be easy to remove as I won't use it, but maybe it's something I should leave be, as I could use it down the road if I knew what it was. GARY N4KVE
ramal121
Lots and lots of watts
Calif Whine Country
Yes it's a KCT-19. If it's too ugly for you right now, it can simply be removed from the radio, no mods to undo (except the single yellow wire for external speaker, you would have to plug internal speaker back in).
N4KVE
PALM BEACH, FLORIDA
The speaker is still connected in the radio. One of the wires of the harness taps into the speaker wire. These little radios are real good, & even though it's rated as 450 & up, it works fine in the ham band w/o retuning. I used to have an 830, & the rx did need a bit of retuning for 442 rx. GARY N4KVE
