Does anyone know what the active control channel is for Taney and Stone counties on the P25 moswin system is? I have a Bluetail technologies micro P25RX, and it would help me from entering each control freq to find out which is the active one……
Yes I know, but I was wanting the current control channel so I don't need to put in all of them in order to find out which is the active one.....ThanksAll the MOSWIN info is in the database: Missouri Statewide Wireless Interoperable Network (MOSWIN) Trunking System, Statewide, Multi-State The control channels are in red, and can change among them, so all need to be programmed.
I recently worked with a member whose scanners all stopped working. The system switched to an alternate control channel frequency. The member had only one control channel frequency programmed into the site. It is best to enter all of the control channel capable frequencies. On a Harris system, any frequency can be used as the control channel and it often rotates. In that case, all frequencies in the site must be programmed.Best to enter them all
