So I'm monitoring one of 6 sites of a smartzone system (Palmetto 800 in SC) last night, and I noted that my scanner (a PRO-96) was constantly trying to track talkgroup 57600 on voice frequency 853.4375. However, there is no audio and it's been doing this for at least the last 24 hours.
57600 is not a known active talkgroup, and 853.4375 is not a frequency licenses to the site. The scanner tunes to the frequency, then scans, then tunes the frequency, then scans, over and over. I can lock out the talkgroup and the scanner works properly.
I ran Trunk88 on the site, and sure enough, 57600 shows active on 853.4375 continuously, with no RID associated. It's as if there's something wrong in the data stream on the control channel.
Has anyone ever seen a similar problem like this, or know what might be causing it?
Brian
Brian
