Hey, a question for all you Motorola techs out there.
Is there an adapter, or some other way to mate an antenna off of a Motorola 800 MHz radio to a scanner with a bnc female antenna jack. I'm having some issues picking up p25, and thought if I could put a professional antenna on the scanner that was designed for everyday use on 800 that it might help some. Any suggestions? I know Motorola uses a special type of reverse sma connector. Motorola part numbers would also help so I know what to look for.
Thanks in advance
Thanks in advance
