ADCR25 P25 / DMR Receiver
RayAir
What's with the encryp key thing? There's no way it does brute force to obtain the key. Keys are designed not to be exposed from software. Even partial parts of the key.
Key ID number and key value must match exactly for proper decrypt on authorized radios. KID is sent OTA.
As far as the actual key goes, well, that is not sent OTA but all the information needed to decrypt is in the raw signal.
Pt XOR Ct = key stream= what secret key + MI generates that key stream = secret key.
Decent ciphers use an IV (MI) so the key stream isn't predictable. However, the key space must be large enough to resist a brute force attack. I'd say large enough today would be an 80 bit key , 112-128 bit key for long term protection and 256 bit for long term and protection against any currently known quantum algo.
Anyway, if you get this digital receiver please let me know how you like it.
buddrousa
I now have full intentions to order the VHF board and would love to see a board cover the 700Mhz band also. I still would like to know if I can run multiple boards on the same computer?
Could I run a VHF board and software?
Could I run a UHF board and software?
Could I run a 800 board and software?
All at the same time on the same computer?
buddrousa
Hello Charles!
1. VHF is a one unit with the gap between 160 and 164 Mhz.
2. Yes. First run first software and connect first receiver. Then run second software and connect second receiver.
3. VHF is available for order.
Andrey Bratolubov
Воскресенье, 10 января 2016 г., 23:37 +0300 от
1. Is the VHF version one unit or two units?
2. Can I run the UHF and the VHF at the same time on the same computer by running the software two times?
3. What is the wait time on the VHF unit?
I received my UHF faster than you stated thanks for the fast response I was still looking around 1-24-2016.
If the answer to question #1 and #2 are yes please send a paypal invoice.
Charles
Forts
Ontario, Canada
Read back thru this thread, I'm sure the reason for the gap is posted here somewhere. It's the only reason that I haven't purchased a board as well.
kayn1n32008
ØÆSØ
Sector 001
If not n this thread, there is a thread over on P25.ca about this board. Pretty sure it explaines why the gap on vhf.
