ADCR25 P25 / DMR Receiver
nick223
Ottawa Illinois
RU3ANQ
Just got your email, so you are saying it will work for DMR Motorola Connect Plus (TRBO) system? Right now I have to run dsd plus and 2 sdr dongles one for the control channel and one for voice channels.
But now this will work is what your saying?
RU3ANQ
Moscow, Russia
FW 5.9 supports:
DMR systems including MotoTRBO (conv only).
APCO25 phase 1 systems (Conv and Trunking)
NXDN (IDAS/NEXEDGE) Conv.
Yaesu C4FM System Fusion. Digital modes.
TRamrod38
FW 5.9 supports:
Does it do both 6.25 and 12.5 on NXDN and does it come with the latest FW and SW already installed, What is the cost for 1.
buddrousa
The information you ask is posted on the website and here if you will read this thread NXDN 9600 and NXDN 4800 are 6.25 and 12.5. Here is the website go look it is in Russian you will have to translate the site and order this by Email. The one thing is this is a band specific receiver only you need 150 meg order VHF you need 460 order UHF you need 800 order the 800 receiver. BE WARNED THEY DO NOT WORK IN THE RAILROAD BAND 160 to 164 is skipped due to the cpu he is using.
ADCR25_PRO2. APCO25/ DMR/NXDN(IDAS/NEXEDGE)/YAESU FUSION RECEIVER. Unit price $179.95. Free shipping WORLDWIDE! - 6
johnls7424
Somewhere in NJ
These receivers aren't cheap. Sounds like not a bad deal though. Personally I think I'll stick with my SDR Dongle and DSD+
RU3ANQ
Moscow, Russia
Yes, it support both 6.25 and 12.5kHz NXDN with the real BW filtering. IF BW 5kHz for 6.25 and 10kHz for 12.5.
Yes it comes with latest firmware and software. Firmware can be upgraded easily via UPGRADE function for free of charge.
RU3ANQ
Moscow, Russia
SDR dongle + DSD+ good idea but its RF parameters are not so good as usually needed.
ADCR25 frontend has far better RF parameters.
Also note that ADCR25 can work in fully stand alone mode. It can do P25 trunk tracking, memory scanning and simple voice decoding without a PC at all. Simple power it up.
Also ADCR25 can do search for DMR, NXDN, Yaesu C4FM and P25 channels with logging.
TRamrod38
Will it do all DMR, NXDN, and P25 in the stand alone mode also or are you limited to one or the other at a time. What i'm asking will it scan all different digital systems at once or are you limited to just one without changing it to another digital system by PC.
RU3ANQ
Moscow, Russia
It can decode only one DV standard at a time.
It can scan memory in stand alone mode. Each memory defines frequeency and air interface.
Yes, if you want to change AIR INTERFACE you need a computer with control software.
