Hi all,
The idea of turning some SSB-less but otherwise decent receivers into something more useful via an external BFO has recently grabbed my attention.
I hear that many people have issues with the TenTec universal BFO kit because they find it necessary to retune the slug on the BFO everytime they change frequency on the radio. Why is that? I thought the TenTec BFO kit just oscillated at a *fixed* 455 kHz (well, a little bit tunable by the pot) and injected that into the last IF stage of the host receiver... surely no re-tuning would be needed?
A DIY circuit using a fixed 455 kHz ceramic resonator also looks interesting:
FlashWebHost.com - SSB ADAPTOR. Resolve SSB Signal on Broadcast Receiver.
With some simple mods, that ceramic resonator could be capacitively 'pulled' off frequency by use of a varicap diode to provide some tuning ability, in a similar way to the TenTec kit.
One last question - if using either of the above circuits and you wanted to install them permanently inside a host radio - assuming there's the room available to do that - what's the best way to mix the BFO into the last IF stage? One arrangement I've seen used a ring diode mixer or a S042P mixer IC, but could it just be injected into the last IF stage at some point and let any non-linearity of the detector do the mixing? Or is that too simplistic?
