adding 700 mz channels- what radios
COMCOM
Alexandria
can handle the transition when 700mz channels are added to an 800 site ?
xts 1500? 2500? 5000 ?
which radios have to be replaced ?
monitor142
California
That's a loaded question. The portables listed below may work but depends on the system type and flash options in the portables. If you are stuck on /\/\, you can add the APX7000 with 700/800 option. Also there are other manufacturers that make 700/800 P25 capable portable radios such as Harris, Kenwood, Thales, EFJ, and others.
Is it an existing P25 system or a smartnet/zone system that will be upgrading to ASTRO25??? It does matter if you are looking to buy forward compatible radios now with a pending system migration to P25. In that case you either go Motorola or EFJ with the right options.
