Adding a Frequency to Whistler 1080
Once you make a conventional frequency you can add it to a scanlist and give it an alpha tag etc. It goes into the Scanlist you save it to. If you don't assign it to any? it will go to the default list which is 001 scanlist. To monitor any object in a scanlist you press "menu" then scroll to browse objects and use <---> arrows to look through the Scanlists for the object you saved. Press the play/pause button and it begins to monitor the object.
