Adding a SWR function to BITX40
beamin
I was reading through the code and saw this:
* Display Routines
* These two display routines print a line of characters to the upper and lower lines of the 16x2 display
void printLine1(char *c){
if (strcmp(c, printBuff)){
lcd.setCursor(0, 0);
lcd.print(c);
strcpy(printBuff, c);
count++;
void printLine2(char *c){
lcd.setCursor(0, 1);
lcd.print(c);
* Building upon the previous two functions,
* update Display paints the first line as per current state of the radio
* At present, we are not using the second line. YOu could add a CW decoder or SWR/Signal strength
* indicator
How would you add a SWR function to the second line? This would be very handy since i make my own antennas!
Kb2Jpd
New York City, NY
* Display Routines
lcd.print(c);
count++;
lcd.print(c);
* indicator
Start here: http://www.na0tc.org/lib/exe/fetch.php?media=technical:homebrew_swr_meter.pdf
I would design the circuit just for reflected power back, not SWR. Tune your tuner or prune your antenna for minimum reflected power and you are good.
All you need is a ADC (analogue to digital convertor) and some way for it to be read by the microcontroller running the display.
beamin
So this is the circuit you add?
BITX Hacks
Im legally blind so im having a bit of trouble finding the code and parts list.
beamin
i forgot to add Im really new to arduino and electronics so that first example seems a "bit " over my head.
But I did figure out how to build a power supply from scratch as well as the antenna.
Kb2Jpd
New York City, NY
BITX Hacks
Then your solution is a simple one.
I worked with Dan Kb2Mlh with making audible SWR/Power meters for him. He is also a blind ham. I used to make a circuit called a Voltage Controlled Oscillator and connect the circuit across the meter movement.
Tuned it for lowest SWR. The circuit I used in the past was a 555 connected to a speaker and the power switch was a mercury switch. You tilted the meter upward, you did the tune, then rested back down and the circuitry would shut off.
http://www.learningaboutelectronics...d-oscillator-VCO-circuit-with-a-555-timer.php
Maybe it's time for that circuit to make a reprise.
