Adding Feture to MTS200 XTS5000 etc
ronenp
Hi there
Say I have Radio with SmartNet and I want to add SmartZone OmniLink Feture
What shouldI do
Should I get the Flash that contain the Already installed fetures in the radio and include also the new feture ? or
should I Get only the flash code with this option only and flash the radio ? and if i flash it only with this option will it *** it to the eisting Fetures already programmed in the radio or it will erase them ?
Please Advice ?
Thanks Forward
Ronen - 4Z4ZQ
Ronen Pinchooks (4Z4ZQ) WebSite
jim202
New Orleans region
Hi there
What shouldI do
Please Advice ?
Thanks Forward
Ronen - 4Z4ZQ
You are going to have to go to a Motorola shop to even obtain the flash upgrade your looking for. No one on here will have anything to hand out to you that will work. Adding a flash upgrade to most radios will not take anything already installed out unless it causes a conflict. Only the Motorola system can provide you with the exact details and cost. Then when the flash shows up, the Motorola shop will have to program it into the radio.
rescue161
KE4FHH
Hubert, NC
Don't use lab software on the MTS2000. You'll more than likely get a Toolproof error.
When you order a Flash Upgraded, you have to give them the model number, serial number, and the current Flash that's in the radio. Motorola will build you a flashcode based on that info along with the new features that you want, so you won't lose any old features. I say you won't lose the old features, but if it's a hacked radio and they don't have it in their system, they may [will] take any features that were never paid for away.
SmartZone is not a cheap upgrade either.
