Modern radios can hold a ton of frequencies but programmed like that, I miss a lot. So, each one of my scanners is a scanlist. I also miss a lot if using one radio to monitor my local trunked system so I use two scanners. With the different sensitivity between GRE/Uniden units, it makes this work.
Would have went with four more BCT15Xs, but the 410 is $60 less per radio right now and will more than do the job. Can't wait to get these in and get to programming.
I currently am using four inexpensive scanners, divided between my home and business for my non-trunked conventional scanners. Two, 410s will be used for this adding the Alpha Tag capability. For the same reason, for my trunked system, I will be substituting two, BCT8s with the 410s.
I had been strictly a Uniden user till the PSR-800. Though I don't need digital right now, I love what GRE did with this unit and can't wait for the 410s to arrive.
