Brand new user here. Just took the scanner out of the box this afternoon. Didn't do anything with Sentinel software. Put in my zip code and started scanning, I'm not sure how but I managed to put my cities police dispatch into a favorites list and set quick key to 0. My question: If I stop on another frequency I want to monitor, is there a way I can immediately add it to that favorites list? Thanks.
If you just 'received the scanner' this afternoon, and 'haven't done anything with Sentinel', then it's likely that the database in the scanner is well out of date. Press the Menu button on the scanner (the bottom one on the left side).
Scroll down & select "Manage Full Database"
On the next screen, select 'Information'
You then see the date for the database in the scanner. The most recent update is 05/09/2021 (this past weekend).
Install Sentinel (if you have not already done so) and update the database. Once you have done that, write the update to the scanner.
While, long term, you likely would be happier with one or more Favorites lists containing what you are interested in, you can still scan using the database, your location, and a range. By having the latest database in the scanner, it will more accurately cover the current frequencies in use in your area.
