So I was reading through the various fixes here on the forum to improve P25 decoding (audio quality). I followed Upmans instructions and changed the Band Default and Default Range.
However, I am currently monitoring two P25 systems. Both of which audio quality is lacking. One system is (Bergen County Trunked 472.XXX Mhz Range Simulcast) PHASE 1 and the fixed worked beautifully for that system.
I am also trying to monitor a PHASE 2 system in the 720.xxx MHz range (NJ inter. System) . My question is, now that I have adjusted the band default to the (400.000Mhz 12.5 + FM Modulation) for the Phase 1 system and it has improved how do I Improve the audio quality for the 700Mhz system?
As I understand, Upmans fix is a scanner wide default change correct?
Will this effect any of my conventional systems?
Thanks guys...
Thanks guys...
