n5pwp
I've been monitoring ADSB for awhile and I've seen these 'extra' blips to the side of the usual 1.090GHz. I'm running SDRUno to monitor using their ADSB plugin. Apparently it locks the filter bandwidth down. Usually I can stretch that window out. Also, if I select a different filter in the RX Controller window it doesn't make it any wider. Are those ADSB pulses for A/C also? Is there a way to monitor them? I guess drop the ADSB Plugin and just tune to that frequency and see if Dump1090 decodes it?
Mike
Mike
