Advanced Receiver Preamps
302HO
I am looking into an advanced receiver preamp model P30-1000/11VD.
Does this thing run off of a battery or do you have to run wire to it?
I have an Icom R20 i would like to use it on.
thank you
MB
North East N.Y.
Great choice! I have a couple of Advanced Receiver preamps. They work great. I especially like the P150VDG, 150-160Mhz +24dB GaAsFET preamp. This thing is unbelievable on VHF-Hi. My scanners connected to this receive all kinds of transmissions that even my ICOM and Motorola VHF-Hi commercial radios will miss.
They are powered by a 12V power supply. You can purchase one from Advanced Receiver or from Radio Shack. You can also use a Radio Shack 12V DC car adapter. As with all adapters, just make sure you wire it with the correct polarity.
302HO
I only have read "good" about those amps. I wish you could run em' off of a 9 volt battery though. I have also read that they are "clean" amps too.
thanks guys.
fineshot1
NJ USA (Republic of NJ)
thanks guys.
303HO - You did not mention where you are located. Just bear in mind if you are in a RF dense urban area while using a very high gain very wide banded preamp you could experience front end overload and or intermod in your portable scanners receiver.
