I'm about to rewire my car (2011 Ford Fiesta) and I was hoping to get some advice and ideas from some of the experts here. I'm including a diagram for reference.
Because of my after market alarm and remote start kit, I have a parasitic drain on the battery that discharges the battery after sitting a few days, so I am hard wiring a circuit for a 2 amp battery tender. It will go through a relay set to cut it off from the battery when the engine starts. On the other side of the relay, it will connect to a voltmeter (with power switch) and the car battery.
Off the car battery, on the positive side I have two fuse-able link studs. One is 40 amp and the other is 70 amp (they will be fused to 35 and 60 amps) and will be either 10 or 12 AWG wiring. They will both be wired inside the cab to relays which will be ignition triggered by a unused 20 amp ignition triggered circuit. The 20 amp circuit will feed a small fuse block, which will then feed lines to the battery tender cutoff relay, both lines off the battery and eventually a dash cam. I am choosing to install the relays as I have left equipment on in the past and have drained the battery and want to eliminate that from happening again.
Off of the 70 amp circuit, after the relay, it will feed to a fuse block with ground, which will feed to a 400 watt inverter, and a mix of anderson power poles, standard automotive accessory outlets and also a binding post. This circuits and sub circuits will ground back to the fuse block and ultimately directly to the car battery, due to the inverter requiring it. There is no monitoring circuitry for the ground side of the car.
Off of the 40 amp circuit, after the relay, it will feed a West Mountain Radio ISOpwr+ (Plus) Auxiliary Battery Isolator, which will feed a fuse block that will then feed a Anytone AT-D578UV dual band radio (max 15 amp), two scanners (2 amps), a multicoupler (less than an amp) and any other future radio. The battery isolator will have attached to it a small, sealed lead-acid battery of 7-20 amp hours, designed to power the RF systems temporarily while the car is off. At this time, there is no plans for sustained operations in the vehicle while the engine is off. I'm installing the isolator after the cutoff relay, as it will allow me to add none battery powered equipment to the circuit in the future if needed. The circuit will be grounded to the car frame.
What do you think?
