Advice Needed for Getting Back into CB Radio
rfunger
Hi all, could use some advice. Was into CB radio back in the 70s and am interested in getting back into it now - I have a daily commute of 100+ miles day/five days a week and would enjoy the interaction. I commute in a compact Chezy Cruze and am interested in a small, but capable unit with probably a magnetic mount antenna (I've haven't seen many good reviews of handheld units). Ideally I'd like SSB too but that might not be possible in a small unit. Any recommendations on radio/antenna and where the heck to put it in a Cruze? Thanks.
milkman21218
Baltimore, Maryland
The Uniden Bearcat 980 SSB is a new SSB radio that may work for you. I like the Sirio pl 5000 antenna. After uses a Wilson 1000 & 5000 Mag mounts for many years. I found out about the Sirio antennas they give me about 5-10 miles more talking to other mobiles. They cost a few dollars more than the Wilsons. But the added range makes it worth it to me.
Uniden Bearcat 980 SSB - (Overview) New AM-SSB radio from Uniden - YouTube
Randdon
Washago, Ontario
Milkman exactly the same outfit I have just purchased. I bought a Wilson 5000, then the next day after more research I bought the Sirio 5000 PL, just waiting for it to arrive now.
Rfunger, I have the same car and I am asking the same question. It is looking like it may have to go on the passenger side mounted to the centre console somehow. I haven't figured that one out yet. The pilots seat is too congested and the passenger side, due to size of the car is in easy reach. Otherwise I was thinking on the top of the dash some how, but that is for later on to look into, as it will not look good and may not be safe. I have the BC 980 and will be magnetically roof mounting as both antenna's are base loaded and need to be above the plain of the car.
If you come up with a good mounting location give us a holler. I have not had the time to sit in the car and hold it in the various proposed mounting locations to figure out fit, worst case it goes into my radio room ...
TheSpaceMan
Westchester County, New York
SSB is definitely the way to go! I have also heard very good reports regarding that Sirio 5000. You might want to consider a quick disconnect mount for your radio, so you can easily detach it and bring it inside or put it into the trunk.
Randdon
Washago, Ontario
Can't wait to get on lower 38 again! A quick connect mount is a good idea! But will probably leave it in most of the time. Not worried about theft where I live and I park right outside the office window. Just wondering how dumb that big whip will look like on top of a cruze eco ... lol
RC286
Winnipeg MB
Grab a K40 with the trunk lip mount. My friend has had awesome luck with a trunk lip mount on his Malibu, should work just as good on the Cruze. As for interior, Ive never seen the inside of one of those cars. Post a couple pics and maybe we can find a space. Usually those center consoles are pretty hollow. ;) Though that depends on how invasive you want to be on your cars interior.
Do you have a radio in mind?
milkman21218
Baltimore, Maryland
I will put my Sirio 5000 up against any K-40. I use to run K-40 and the Sirio will give me 5 or more miles over it. I've seen up to about 20 miles more over my Wilson 5000. While parked swapping them out. And the K-40's crack to easy for me.
Randdon
Washago, Ontario
rfunger, just had a brain moment. In driving into work this morning I started looking around the cabin and had a bit of an epiphany. I am going to on the weekend look at mounting it in the little pocket in the lower drivers door! Its accessible in that location, viewable while driving and your not whacking your knees on it as if attempted to mount it under the dash on the drivers side. It is no longer in the passengers ****pit anymore and is somewhat hidden from view and would be dark enough in the day time to view the control panel.
What do you think??
JustLou
NY/NJ
+1
A Wilson 5000/1000 is much better than the K-40.
JustLou
NY/NJ
I sure think so! And I find Sirio to be better than the Wilsons.
I actually misread your post about the Sirio. ;) Oh well. I have no experience with the Sirio, but do with the Wilsons and K40. The K40 has to be the most overrated antenna ever made.
Randdon
Washago, Ontario
DNJradio just charged my credit card so the order has been entered, now its a waiting game!! When will my Sirio Performer 5000 PL be waiting at my door !!!
Also rfunger, CarID has bezel kits IF you wanted to change the standard radio from it's own format to 1 DIN format. Leaves room for a second box, so a CB or Scanner. But you need a few gadgets which run the cost up pretty close to $300 just to stick the radio in the dash!
rfunger
I'm still not sure where I'm going to put it yet - will have to check out the driver side door pocket. I'm thinking about merely putting it on the passenger seat (with either a cigarette plug-in adaptor or hard wired). But I'm leaning toward the Sirio 5000 antenna with a mag mount. My problem is bit more complicated, however, in that I also want to put in a 2m rig! May just have the passenger seat full of radios!
milkman21218
Baltimore, Maryland
That is really a problem when you don't have enough space for radios. Maybe under the dash will help some. But seats do work. I wish you the best on finding the best location for your radios. Let us know how you like your Sirio.
73
