I appreciate all the ideas, i’m still looking for any ideas that might help. Here is a quick summary of what my AOR 8200 MKII is doing. It will turn on and function normally, including using the PWR button to switch to other memory banks by pressing power then the number. It scans fine and seems normal, it just will not turn off when I push the power key to turn off the scanner. This includes using both batters and the wall power supply, neither will turn off the scanner. The only way to turn the unit off is to take out a battery or unplug the power supply, depending on which is suppling power to the scanner. I have tried holding the PWR button for a couple of seconds, I have tried a spot reboot (and would do a hard reboot but it doesn’t appear possible). I thought about taking the keyboard out and using keypad fix (and I may still try that out of desperation) but because the key works for everything but turning it offi am thinking that with not be the fix. I don’t know if I accidentally turned something on or off causing the problem, but that does’t really make sense either. Any additional ideas, suggestions, etc. would be appreciated. I’m dumb founded.
