I don't think the M-RK is ProVoice capable but I may be wrong.
I would bet they are Aegis. Try this site and compare them to what you hear:
http://www.kb9ukd.com/digital/
The possiblity exitsts that they could be using digital without encrypting it. It's an odd concept if you're familiar with Moto stuff but the manual says so:
Unencrypted Digital (Aegis and ProVoice):
· More secure than analog (clear) voice communications and provides protection against monitoring of communications (IE: scanners).
· Limited to no communications protection if a radio is stolen, depending on the System.
VGE Encryption (Voice Guard, Aegis and ProVoice):
· More secure than analog (clear) voice communications.
· Provides very high level security against monitoring sensitive communications, with 1.8 x 10 to the 19th power possible cryptographic codes. (64-bit code)
· The number of possible cryptographic codes is increased to 3.4 x 10 to the 38th power with the use of a CUE code (Customer Unique Encryption code). (128-bit code)
· If a radio is stolen, changing the cryptographic keycode in the remaining radios maintains communications security of your system.
· This digital voice algorithm is not exportable without a license from the US Government.
DES Encryption (Voice Guard, Aegis and ProVoice):
· Provides very high level security against monitoring sensitive communications, with 7.2 x 10 to the 16th power possible cryptographic codes. (56-bit code)
Copyright © M/A-COM, Inc. All rights, including trade secret rights, reserved.
