AEP on Flat Top
wvscanner
Beckley, WV
Does anyone know what the correct settings for AEP on the Flat Top tower? RR shows LCN1- 854.9125, LCN2-858.3875, LCN3-859.3875, and LCN4-860.3875
The FCC Database also show a 5th channel as 860.8125 for that tower.
I can get 1, 2 , and 3 to work, presuming that I don’t hear the control channel noise on LCN3 while I’m scanning them. However I can not get the 4th and 5th frequency to work in the scanner. I’m not sure if they just have a unique channel number above this or if they are another control channel from another tower running it.
For testing I can take another scanner and run those 2 freq. as conventional channels and I can hear them talk on those 2 channels to others that are on the system that my trunking scanner will pickup. The trunking scanner is the bc246t set on edac wide.
Thanks for Any help!
Scanning Beckley
Jeffery Smith
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
If the first three work fine, flip-flop channels 4 and 5. Try 4 as 5 and 5 as 4....
