You might not have much luck, for various reasons. I don't know exactly where you are, and I don't know if you are just using a ducky antenna or an outside antenna for the 800 mhz band with quality low-loss coax. So, it's hard to tell if you would pick up any of the sites from your location.
401 Ansted
403 Coal Fork
405 Madison
423 Hernshaw
424 Bolt
485 Elkhurst
Now, those sites are the ones that pretty much surround the Kanawha / Fayette line. However, I'm not sure that the LCN order has been _confirmed_ on any of those sites. And if the LCN order (as listed in the DB) has not been confirmed, you likely will never copy traffic.
1. Decide in your mind which one or two sites are the closest to you geographically
2. Using your scanner, tune to EACH frequency listed at each of those two sites
One frequency on each site will have an EDACS 24/7 control channel. It'll make a funky sound (if you've never heard an EDACS control channel).
If you tune to every frequency on the closest two sites and you hear _nothing_, then you simply aren't picking up the sites and need a better antenna system.
If you tune to every frequency on the closest two sites and you find a control channel (its not voice, its a control channel - you'll clearly know what it is), then determine if the signal strength is pretty good.
If the signal strength is pretty good on a particular site, program the site into your PRO-652. Only program sites in if you know you can pick them up with decent signal strength -- again, figuring that out by finding the control channel for each site and looking at signal strength.
Assuming one of the sites above is close enough to you for you to get a good signal on the control channel, program the site into your scanner just how it is listed in the DB and keep your fingers crossed.
NOTE: because I don't know if the LCN order for any of those sites has been confirmed, you may not be able to trunk track (follow conversations) even if the site is trong enough for you to pick up until you determine the proper LCN order.
Unless you are extremely lucky, I have a feeling that either you won't be able to reliably pick up a site due to your location / antenna setup OR if you can pick up a site it might not have the proper LCN order listed in the DB and thus you won't be able to follow voice conversations.
One thing you definitely want to do, if you program in one of those EDACS sites, is to add a Group WildCard and a Private Wildcard for the system. That way, you'll hear whatever talkgroups are active even if you don't have those talkgroups programmed in.
Hopefully somebody down in that neck of the woods will respond and indicate that some sites close to you are online and that the LCN order listed in the DB is accurate. I just don't know.
Mike
Mike
