Thank you for the reply! In the original thread you wrote that the battery still had 3.06 volts, the same as mine is now, but it was actually dead?
I recently replaced the memory battery in an old Icom IC-28A that I got recently, and amazingly the old battery from '99 was still holding a voltage after 21 years, and still maintaining the radio's memories. But, to be safe, it was replaced. Have replaced many memory batteries in radios, all...
forums.radioreference.com
If it was dead, and you replaced it and were able to reprogram frequencies, that answers my question. Many web pages and some Icom instructions say you must solder in a temporary 3 volt source to protect the memory circuit when you do the changeout. If not, they warn the memory circuit may have to be replaced, or sent to Icom for reprogramming (of course they wouldn't work on an old radio from the late '80s). My original manual for the radio just says to send it to Icom to change the battery.
In fact I used a coin battery holder and alligator clips to make a rig be able to connect it just below the battery tabs when I unsolder it, but haven't received the new BR2032 yet. Just a lot of conflicting info out there on these old radios, and I'm being very cautious because I've repaired several issues on mine, and it's working very well now. I think I'll still try to use the backup rig I made, and solder in the new battery. 73's Tom.
This is the new battery:
