AFEDRI SDR Network Control Box x2 Software v4.11
D
DaveNF2G
Guest
Sdr network control box was updated to v4.11 you will need this update if your are running HDSDR v2.60
Copy and paste the contents to your hdsdr folder
Wouldn't it be simpler to extract the contents of the zipfile directly to the HDSDR folder?
brandon
SoCal
That would work, but if the user is on Windows 7 and HDSDR is in Program Files, the unzip might not work depending if they have UAC turned on. Cut and dump in a lot quicker IMHO. :)
D
DaveNF2G
Guest
I understand. I did not extract the archive pending the answer. As I am using XP, I will extract it to the HDSDR directory and expect it to work.
Did I just say that I would expect something to work under Windows? I must be losing my mind. :D
