Affordable SIM Card for My Network Radio - Suggestions?
Maniliaq
Hey all,
I’ve got a Network Radio that I mostly use for Zello, and it needs a SIM card compatible with the AT&T or T-Mobile networks. I’ve heard that I can get by with a basic plan offering around 200 MB of data per month, and I’ve seen a few options out there for about $5 a month.
Does anyone have suggestions for a good, reliable SIM card provider? How’s the coverage been for you with those cheaper plans?
NewJerseyOldListener
Hey all,
Tello Wireless. They use T-Mobile Bands.
https://www.tello.com
KD9FAL
Cape Girardeau, MO
Mobile X from Walmart works great for my needs; however, I believe it runs on Verizon's network
I pay $2 per month to keep active and $2 per gig. If you don't use the data you paid for, you get a credit on your next bill.
You create your own plan. So, if you don't need call or text, you only pay for the data.
dorcse
I use Simbase. $0.02 a day to keep it alive, $0.03 per MB for data. I've used it seamlessly in Canada and the US so far.
Can I ask what radio you are using with the Simbase service? I'm looking at some cheap KSUN radios to play around with, but some have mentioned they will not work with SIM cards in the US.
mitchk
Champaign, IL
I have a KSUN Zello Android ZL18 arriving tomorrow. Can anyone confirm a data SIM card that will work in the US? Thanks!
n3obl
ØAES-1024
PA
I completely forgot about this thread, I went and got myself one of the simbase cards and it works great for my laptop.
Sorry didnt see your post was few months prior.
mitchk
Champaign, IL
My Z18 arrived. Works great on WiFi.
Just an activated a Tello SIM with a data only plan. Getting a strong wireless signal. SIM status is showing "TELLO", GSM, and "Voice in Service/Data Out of Service." It's assigning an IP number, but Zello is stuck on "Signing in..."
Tello customer service only says everything looks good on their end, so the device is likely unsupported.
Any ideas would be greatly appreciated. Thanks!
mitchk
Champaign, IL
check to see if your device can roam? when I setup my laptop its has to be in roaming to be able to use the data.
Thanks so much. I found a solution:
SETTINGS
NETWORK SETTINGS
ACCESS POINT NAMES
(THREE DOTS IN UPPER RIGHT CORNER) New APN
APN: wholesale
(THREE DOTS IN UPPER RIGHT CORNER) Save
Select "wholesale" APN.
REBOOT
Working perfectly with Tello mobile data!
4RC7K05
I recently purchased a KSUN KSW-ZL8668 Dual Mode PoC Radio. I'm not sure what type of SIM card will work with this device. I contacted Tello but I ended up more confused with their response. This is a 4G phone but I don't know if it supports VoLTE.
mitchk
Champaign, IL
My KSUN Z18 ended up working fine with Tello (see post above yours). But Tello uses T-Mobile towers and coverage wasn't the best in my area. Switched to Simbase (they use AT&T, T-Mobile, Verizon towers) and had great coverage.
Pittsboro IN
thanks for this info, I'm paying T $140.00 a month for 4 unlimited lines. I passed the IMEI check. I've been on some disaster deployments where my phone worked but my team mate's Verizon did not. Overall I'm glad I dumped Verizon, had lots of drop outs in our home going from front to back with them.
