Agency removal and addition
Reconrider
Inside the Galaxy
Radio Galaxy
You don't remove anything. You use the submit process
You don't get an agency removed, it gets marked as 'deprecated' and gets purged by the system BUT you need to have proof that all equipment was removed from the place it was at.
kd5pqv
coleman texas
I want to remove an agency from my agency list and add a different agency to my agency list how do I achieve this.
Reconrider
Inside the Galaxy
Radio Galaxy
Not sure what you're trying to remove it from..
What scanner/radio? What program are you using\hand programming?
kd5pqv
coleman texas
I want to remove my Texas Alcohol agency and add the Texas Department of Public Safety.
mc48
Monroe County, NY
In Sentinel on the front database page not an edit screen, you can remove an agency by right clicking on the name then select remove from favorites list, to add, find the agency you want to add (from main database)and select append to favorites list, then select where you want it to go. Hope this helps.
