Air Canada at PIA
jonesyxvii
Richmond Hill, ON
Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 5_1_1 like Mac OS X) AppleWebKit/534.46 (KHTML, like Gecko) Version/5.1 Mobile/9B206 Safari/7534.48.3)
Does anyone know if the Air Canada trunked system at Pearson is still operational? The RR database says it was last updated in November 2011 but when I was out at the airport this morning I picked up nothing. No talk groups, no control channel.
exkalibur
York, Ontario
Highly doubtful. Last I saw, Air Canada employees were all carrying Motorola i305 radios, so I would assume they're on the Harmony system like everyone else these days.
pathalogical
Toronto, Canada
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
Interesting - several years ago I tried to listen and also checked its licenses and a bunch of the frequencies had been dropped and picked up by TELUS iDEN, and I got zero activity at the passenger terminals, just as jonesy said.
However, the licenses are there again. I didn't try tuning in to it in July, thinking it was gone and replaced with the Harmony stuff.
pathalogical
Toronto, Canada
Confirmed. The system is active, but I can't hear it from 401 & Weston Rd. Along the 409 it started coming in scratchy, arrived at Carlingview Dr around 1pm today and no hits at all in about 15min of listening ! Drove to Orlando Dr (Wendys) and it was non stop action. I think, you have to find a sweet spot around YYZ to listen to this tsys.
exkalibur
York, Ontario
Yup, you beat me to it! I took a slide by the airport last night and you're right, the system is still alive. My 396 wasn't able to pick it up reliably until I got to around Eglinton on the 427.
smitty9999
Toronto, Canada
Thanks for the info. I'm at Jane / Wilson and nothing was coming through.
pathalogical
Toronto, Canada
Thought I'd also mention that there were some tgid that popped up as wildcard on my pro 106; 748, 752, 672, 624. Probably others that I didn't write down. The talk was all the same about passengers, luggage, flight/gate, standbys etc...
jonesyxvii
Richmond Hill, ON
I've downloaded the system from RR into FreeScan and uploaded it to my 996XT and 15T and neither picked it up while I was at the airport. Weird. I wonder if my programming is off somehow. How do you guys have it programmed in?
exkalibur
York, Ontario
I just dumped all the frequencies in as if they were control channels. Not sure which one lit up.
pathalogical
Toronto, Canada
Use the Splinter System setup.
EDIT: Maybe a DB Admin can add that instruction in the Air Canada page.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I've added that instruction, your Honour :wink:
Usually the disclaimers on ads are "don't try this at home", I think I'll have to review my programming and give it a shot. Thanks for pointing this out. :)
jonesyxvii
Richmond Hill, ON
Wow, having changed that on my 346XT I'm now picking up this system in Richmond Hill. It's very faint but just strong enough that I can run Unitrunker on it. Helps that I'm seven storeys up, I guess.
Thanks for the help getting this working,
Rob
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I've noticed that the control channel today is 853.0500 if that helps anyone.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Let the HomePatrol do it's thing this afternoon on Discovery Mode and logged these un-ID talkgroups between 3 - 4 pm
336,464,576,672,688,704,752,768,816,832,880,960, 976.
Other observations, tg 272 Baggage Runner has the most traffic. All fifteen freq. were being used and today's control channel is 852.8250
02blackss
Brampton, Ontario
I need some help with this one guys........I have programmed it into my 346 through radioreference.......Changed the band plan to Splinter....still nothing. I am in the Dixie and Bloor area in mississauga, quite close to the airport actually. And I am up 7 floors as well.
Anything else I should be changing?
