Air to Air listening
radio10-8
West Coast
I have a large number of aircraft going to and from a bombing range about 45 miles from my work. I would like to listen in on the instructor and student pilots. Any idea what frequencies I would start to try? Aircraft comes from Luke AFB (F-16's, Tornado's??) and Davis Monthan AFB (A-10's, F-16's ) I was told that the conversations can be very interesting between instructor and student. Also Marine Corps aircraft from Yuma MCAS
n3bxv
Severn, MD
Try Searching 138.00 through 144.00 in AM mode, a lot of Military Air to Air Comms are in that range.
DPD1
Typically, if there's an instructor, he's usually in the same plane. After that they might lead a section or something, but they normally are on their own after that. Most AA is between squadron mates when in a section or division. AA's for mil are the hardest to nail down out of everything. 16's usually use VHF for AA, Navy/Marine usually use UHF. Only thing you can do sometimes is just search and hope you stumble onto them. They change often, so a lot of the lists you see floating around are outdated.
Dave
-DPD Productions - Featuring the NEW MilTenna LP Gain Scanner Antenna-
http://eje.railfan.net/dpdp/
