Aircraft band base antenna
ScottE22
Hickory ,N.C.
Any recommendations for a reasonable, simple design aircrft band antenna? Mainly will be used for civilian band ,nearby airport, about 3 miles away, but some terrain masking signals, tower good, local traffic good, ground and more distant needs improvement...
Ubbe
Stockholm, Sweden
but some terrain masking signals... ground and more distant needs improvement...
What are you using as a reference, a telescope antenna on back of the scanner or is it a handheld scanner?
Whenever the signal are blocked by obstacles you'll receive most of the signal from reflections and then placement of the antenna becomes even more important. If I move my outside VHF GP antenna 1 meter I stop receiving the local tower. It starts to receive it again at a location 4-5 meters to the side.
Can you install an antenna on the roof of the house or somewhere else outside or just in a window indoors?
You would try to use an antenna that focus on reception from the horizon as much as possible and not up in the air. Airplanes at line of sight can be received with a wet noodle. If you got the space then a $50 discone will work fine and have the frequency range to receive a lot more than VHF air. To boost the signal you could use a 5/8 GP antenna tuned to 125MHz. You can put together your own 1/2 wave dipole at almost no cost using electrical wire, a spliced coax or thicker tubing for extended bandwidth that you can test at different locations and only requires some working hours. It mostly depends of where you can place the antenna.
Don't rule out pre-amplifiers that works for most people but will be dependent of the interference level at your location and if the scanner are good enough to handle the extra boost in signal. If you ONLY want VHF air from an antenna you can use a bandpass filter 120-140MHz together with an amplifier but you would still need a way to attenuate the signal to a level where the scanner can handle it without loosing performance.
/Ubbe
iMONITOR
Silent Key
S.E. Michigan
Sirio WY 108-3N 108-137 MHz Air Band 3 Element Yagi Antenna $159.00
  • Base station antenna, Directional
  • Wide band, High-gain
  • Highly symmetrical radiation pattern in both planes (E and H)
  • Protection from static discharges DC-ground
  • Made of anodized aluminium alloy
  • Stacked and bayed array for more gain
  • Optional: tilting bracket for +-20°
    Electrical Data
  • Type: 3 elements yagi antenna
  • Frequency range 108-137 MHz No tuning required
    108-118 Mhz @ SWR <= 1.5
    118-137 Mhz @ SWR <= 2.0 (air - ground communication)
  • Impedance: 50Ω
  • Radiation (H-plane): beamwidth @ -3 dB = WY 140-3N: 140°
  • Radiation (E-plane): beamwidth @ -3 dB = 70°
  • Front to back ratio: ≥ 12 dB
  • Polarization: linear vertical or horizontal
  • Gain: 4.85 dBd - 7 dBi
  • Max. Power (CW) @ 30°C: 200 Watts
  • Grounding protection: All metal parts are DC-grounded, the inner conductor shows a DC short
  • Connector: N-female with rubber protection cap
    Mechanical Data
  • Materials: Anodized 6063-T5 Aluminium, EPDM rubber, thermoplastic UV stabilized, Chromed brass
  • Wind load / resistance: 114 N @ 150 Km/h / 160 Km/h
  • Wind surface: 0.071 m²
  • Dimensions (L x W approx.): Dimensions (L x W approx.): 1400 x 910 mm / 4.59 x 2.99 ft
  • Weight (approx.): 1860 gr / 4.1 lb
  • Tourning radius: WY 140-3N: 970 mm
  • Operating temperature: -40° C to +60° C
  • Mounting mast: Ø 35-52 mm
kc2klc
Binghamton, NY
I don't think ScottE22 is looking for a directional antenna, unless he is interested exclusively in signals coming from his local airport. I second Ubbe's vote for an inexpensive discone antenna on the roof - not only do these perform fabulously well, but they are wideband, meaning that they can be used for other monitoring activities as well (if one were to become interested in any of the other hundreds of types of signals out there in the VHF/UHF range).
iMONITOR
Silent Key
S.E. Michigan
The only downside to a discone is it's wide band response, meaning that it brings in all the frequencies you don't want for aircraft monitoring, both VHF and UHF, meaning needless interference especially local strong FM broadcast signals, an VHF airband monitor's worse enemy. Plus the discone had zero gain.
iMONITOR
Silent Key
S.E. Michigan
Sirio GP 108-136 LB/U VHF Aircraft Band 108-136mhz Base Antenna (U Connector)
Sirio GP 108-136 LB/N VHF Aircraft Band 108-136mhz Base Antenna (N Connector)
This is my favorite for VHF Aircraft (Not UHF Mil-Air). It's built to last a lifetime, build quality is unsurpassed. The unusually large diameter gives it greater bandwidth than anything I've seen elsewhere and the price is reasonable.
WB9YBM
The simplest design I can think of is a straightened out coat hanger soldered to an antenna connector with four radials (also made from coat hangers) coming off the bottom of the connector.
prcguy
A simple ground plane will not cover the entire 118 to 136MHz voice portion of the VHF air band. The Sirio fat ground plane mentioned above will. A Discone is used at many airports and the typical scanner size versions like the Diamond D130 and older Radio Shack work very well for both VHF and UHF air bands.
iMONITOR
Silent Key
S.E. Michigan
You might need to add a FM-Notch Filter if you encounter interference from strong FM broadcast stations in your area.
WB9YBM
Considering how relatively close the frequencies are, it's have to be a pretty tight filter--or at least tuned towards the bottom end of the BC band...
iMONITOR
Silent Key
S.E. Michigan
Filter Specs:
PAR ELECTRONICS
STRIDSBERG
N1XDS
ÆS Ø
For the antenna I use for Military VHF and UHF I use the DPD Productions Omni antenna and it works really well when picking up near and distant aircraft of all kinds. I also use my AVANT SATCOM UHF Portable Antenna that also works really well!
Ubbe
Stockholm, Sweden
We have done some actual measurments of FM BC filters and the results are here: FM bandstop filter comparison
The Stridsberg FL201 filter I have are not suitable for VHF Air.
That ZBSF-95-N+ filter seems perfect if you can sacrifice frequencies down to 65MHz, but it is $100.
//Ubbe
iMONITOR
Silent Key
S.E. Michigan
+1
MilTenna Omni UHF/VHF Base Antenna
I'm not familiar with the AVANT SATCOM antenna. What is the cost on that one?
N1XDS
ÆS Ø
+1
These are one of the best satcom land based portable antennas out there on the market today with high gain when picking up communications from pilots, satcom frequencies and etc. I have owned mine for a year now and it never let me down. These antennas are pricey around the
$400 to $900 sometimes more all depends on the seller and what the antenna comes complete or not complete. I paid $600 for mine in excellent condition.
Here's the link to them:
Trivec Advant satcom antennas
