aircraft frequencies, dade county area
harrycaul11
hello,
I want to send my son a scanner to listen to airplanes in the dade county area. ft lauderdale, miami and any military. ill be getting a bct125at and programming it for him. if anyone local can help me out, he lives in the homestead area.
batdude
Florida Db Admin / Florida Forum Moderator
Moderator
East Central, Florida
Homestead ARB
Miami International Airport
Miami Center
those would be a great start!
MiCon
Mike
central AZ
As he listens to the frequencies you provide, tell him to write down and program any frequencies he hears the controller or aircraft mention.
Here are some frequencies used throughout the country:
121.5 aircraft emergency
122.7 small airport advisory
122.8 small airport advisory
122.85 helo advisory
122.9 small airport advisory
122.95 FBO's (Field Business Office providing aircraft services)
123.0 small airport advisory
123.025 helo advisory
123.4 air-to-air
123.425 air-to-air
123.45 air-to-air
123.475 air-to-air
135.95 air-to-air
Once he learns to use the Search feature he can find and identify many more frequencies used in his area.
harrycaul11
thanks for all your help on this. I asked in the milair forum if anyone uses this radio for aircraft monitoring.
BAOFENG BF-F8HP PRO.​
anyone have any experience with this one. it will be used as a scanner for aircraft
wtp
Port Charlotte FL
remember, it is for hams, not scanner users.
  • Frequency Range (RX): 65–108 MHz (FM radio), 136–520 MHz
>>>>>>SO IT DOES NOT RECEIVE THE 118 TO 138 AIR BAND !!!<<<<<<
harrycaul11
'Receiver coverage includes 88–520 MHz FM/AM according to the appropriate band plan" i copied this from the Btech website. i;m thinking that it does cover the air bands.
  • Like
Reactions: wtp
wtp
Port Charlotte FL
OK i kept looking.
Wide RX Frequency CoverageReceiver coverage includes 88–520 MHz FM/AM according to the appropriate band plan
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
Steer clear of a BOWELfang. Pick up the BC125AT instead. Search the forums and you'll unearth hundreds or maybe thousands of rave reviews on air band
CollinsURG
North Carolina
I could not find in the user manual that the Baofeng supports AM mode. Regardless of whether it receives 118-136 or any part of 225-400, AM mode is required. The Baofeng is not the proper tool for aviation monitoring. Stick with the BC125AT.
Also, these Chinese boxes of junk, if they do cover VHF airband in AM mode, it is always 118-136 Mhz. The band was extended to 137 Mhz in 1990. Could you miss much? Yes! There are voice channel assignments there for ATC.
CollinsURG
North Carolina
Airnav.com for all airports including military.
