Aircraft lockout ?
kjfswkr
Hi all,
I am using my 536HP and starting to learn the functions. However, I have locked out aircraft band and still pick up Boston flight traffic. Any idea what other band this may fall under?
73'
kevin
ofd8001
Louisville, KY
I'm presuming that you by you have locked out the aircaft brand on your scanner, you have gone into the menu for Select Service Types and then set Aircraft to "Off".
The next thing I'd do is look at the specific channel you are receiving and see if it has Aircraft for its Service Type. I've found that if I manually add a channel, Sentienl assigns "Custom 1" as the Service Type. So that's a possibility.
kjfswkr
Thanks ofd, I did select service type under aircraft band and it is locked out though still receiving some
kevin
ofd8001
Louisville, KY
Then check the actual channel using Sentinel. . . It might be assigned a different Service Type for some reason or another.
bearcatrp
Land of 10,000 taxes
Having same issue on my 436 but it's department of correction scanning but turned off.
I just made a thread in bug reports about this to see if anyone else is having this issue. Can you post your issue there so we can see if there are more folks having this issue?
N0UDG
In addition, many Life Flight Air Vac operations are often listed in EMS Dispatch.
