Aircraft on 23184KHz LSB
williamGB
Chester, UK
Today, I came across multiple signals around 23MHz.. 2 of which were Gander and Santa Maria.. but the modulation was LSB not USB.. is that normal? I thought HF aero is only on USB? The Gander frequency is 23184 and the Santa Maria 22172. I'm also hearing selcals on 23217, 23250, and 23202 (all LSB) but i was not able to make out the voices. I received these at around 5am in the UK.
William
Edit:
I heard an aircraft on 23202 with the callsign Turkish 904, I jumped on FR24, and the aircraft was over the Atlantic near Bermuda which makes 23202 New York Radio.
williamGB
Chester, UK
Update: I hear aircraft saying "This is CALLSIGN calling Gander on 5616"... but im tuned to 23184. Is my SDR getting overwhelmed by the frequencies?
sunwave
Oklahoma
William
Edit:
That's a wild frequency to hear New York Radio at the hour of your OP. Post for me your RF gains and describe the antenna and which SDR you are using. Also, for your own frequency reference, ARINC has a daily list of active frequencies here Atlantic HF Assignments
If you are running any sort of LNA please provide that info too.
williamGB
Chester, UK
My RF gain is actually 0 haha, and the antenna is a 20m dipole in a V shape made from some old copper wire connected to a noolec balun one nine. I tend to receive New York and Gander around midnight to around midday, then I get Shanwick and Santa Maria from early morning to night time. I actually made my own list with the general time I checked the frequency and I heard something.
ATC CentreFrequencyGeneral reception timeATC CentreFrequencyGeneral reception time
Dakar653501:10, 02:15Gander559800:00
Gander347609:23New York559801:40, 04:30, 06:15, 07:00
Gander561600:25, 01:40, 03:10, 04:30, 06:15, 07:55, 09:30Santa Maria559801:30, 03:10, 04:30, 07:45
Gander889109:25
Gander1127913:30, 16:30
New York550504:30
New York552000:30, 01:40
New York555000:30, 01:40, 03:10, 04:30
New York657702:30
New York658602:05
New York889300:35
New York890604:00, 05:30
Pacific554703:10, 04:30, 06:35
Santa Maria662804:35, 06:40
Santa Maria890609:40
Shanwick349106:45
Shanwick465106:45
Shanwick558304:20, 09:30
Shanwick564908:10, 09:30, 13:20
Shanwick580306:05, 08:10
Shanwick662209:30
Shanwick887913:30
sunwave
Oklahoma
Gander889109:25
New York550504:30
New York657702:30
New York658602:05
New York889300:35
Shanwick349106:45
Shanwick465106:45
Shanwick662209:30
Shanwick887913:30
I am guessing a RTL-SDR if so, which variant?
sunwave
Oklahoma
I'm using the Nooelec v5.
Okay aliasing is the big problem from overload. Your situation warrants adding an attenuator of lets say 20db. A variable attenuator. It is common that people use an attenuator to knock off the signal to stop the overloading. Nooelec v5 uses the Q branch which disables RF gain. With the RF Gain disabled it's cramming everything down the pipe.
Essentially, your antenna is very very good at receiving signals but it is too strong for your v5. Keep your antenna inline and get yourself a nice variable 20db attenuator. That should solve it.
williamGB
Chester, UK
Ahh i see. I'll definitely get an attenuator! Thanks for your help!
sunwave
Oklahoma
you're welcome. I wanted to also recommend the rtl-sdr.com v4. It doesn't use the Q branch. It uses a built-in ring mixer upconverter in quadrature sampling which gives you RF Gain control and no nyquist folding. Attenuators might be expensive, so, If an attenuator is more than $29.99 then get the v4. That's how I would do it. My v4 won't overload like the v3 when RF Gain is properly set. The v4 without the antenna kit is $29.99 on Amazon while in stock.
Will will have to replace the rtlsdr dll in the software you use if you do get the v4. SDR sharp v1919 has the install.bat that will take care of that for you only in sdr sharp.
Latest beta of sdr-console already has v4 dll driver
HDSDR needs a different EXTIO dll for the v4
DSDPlus FL needs the updated dll from base files and new FMP24
radar_hunter
All RTL-SDRs that use the direct sampling mod and not a built-in upconverter will alias the HF spectrum around 14400 kHz. This is not overloading and an attenuator will not help. A low/high pass filter at 14400 kHz would help but the RTL-SDR blog v4 is probably more convenient as a low-cost solution with better HF capabilities.
(14400-5616)+14400 = 23184 so that's why you hear it on the wrong frequency.
Overloading and imaging problems can also occur with the RTL-SDR but they are different problems. For example, FM broadcast interference can be pretty bad on 27 MHz in the normal operation mode, and the solution is an FM band stop filter.
williamGB
Chester, UK
Ahh that makes sense. I was getting a radio station on the CB band, but it's actually broadcasting on 1458!
