Aircraft Transceivers ICOM vs. Vertex
Lynch_Christopher
Winthrop, Ma
I am currently in the process of looking for an aircraft transceiver since I do a lot of aviation monitoring and was wondering which company makes better quality aircraft transceivers Icom or Vertex Standard. I am currently deciding between the IC-A14 or Vertex Standard Spirit (VXA-710) or Vertex Standard VXA-220 Pro VI.
captkel
south florida
I have the Vertex VXA-220 Pro VI
I like all the scanning features and it's portable. I sometime use it on one of my ATC feeds. I know Caleb may disagree on this one but I found it to receive just as well as my BC15X. They have pretty much the same sensitivity. The Vertex does have good selectivity and better adjacent channel selectivity and is not easily overloaded like the BC15X. I think we all agree that the squelch is a little pain to adjust but I can adjust it very quickly now and you can really crank up the volume and make it VERY LOUD. I bought it hoping that I could hear some weaker signals more clearly but that didn't change; to me, at home hooked up to my antenna system, they both sound the same. If you haven't already, download the manual and get a feel for this radio before making a decision.
KEL:)
CalebATC
Blairsville, Georgia
KEL:)
Agreed for most part :)
Squelch is pretty well for being digital, and really doesn't take that big of steps. I keep my radio just right above noise (level 2) it does have a side button where you can break the squelch (hold for two seconds for squelch to stay off)
I found it better than my Radio Shack PRO-163, and with the same antenna. It is better at pulling in those long distance signals. Not by much, but sometimes it is what makes it from being there just above the noise to not hearing it at all.
As Kel said, it is an extremely hard radio to overload- radios that I had to use a FM trap on I didn't have to on the VXA-220. I think overloading is one part that makes this radio better than my Pro-163. Some extremely weak signals wouldn't be audible on the Pro 163, but would be just over noise level on the VXA-220. I think it's the rejection is that reason though, and in microvolts, it is more sensitive. It probably is a little less of competitor at the BCT-15X level, but these RS 163's overload.
Also, has a very great battery life, (at least 6 hours on RX), built like a tank, great customer service, and has its own charging case that is mounted on the desk, so it is like a base radio almost! It's five watts does the job, too. The stock rubber ducky antenna is a very great antenna for being portable, and matches the radio perfectly so that it is submergeable.
Caleb
Lynch_Christopher
Winthrop, Ma
Thanks for the information I appreciate it. I will check out the VX-200. Is there a noticeable difference in the sensitivity on the aircraft band compared to Radio Shack and Uniden Scanners?
mass-man
trying to retire...
Parker Co., TX
I don't know. I have used both scanners and dedicated air radios to monitor ATC freq. here for years...never needed the handheld while flying for actual comms. Seems the scanners are just fine for my kind of listening...local ATC, some enroute stuff and if I find an airstrip in my journeys, tuning to Unicom or whatever. Why not a Uniden or RS or GRE scanner so when air stuff is not there or boring, you can hear other stuff.
That said, I do park a separate radio on the emergency freq...an old ham HT but do hear beacons when they are triggered by accident...
CalebATC
Like I explained, a microvolt difference, yes. Now a noticeable difference- for me, yes as I said before. Maybe not for all people though.
captkel
south florida
If your just interested in sensitivity then Yes, the VX-220 is more sensitive on the VHF airband then SOME of the other scanners. They claim better then 0.8 microvolts, the BC15X is 0.3 microvolts on the airband. My ICOM is 0.5 microvolts. The BC350A that I have are 1 microvolt I believe. An old Regency Digital Flight Scan radio I have was around 1 or 2 microvolts.
KEL:)
