Airline Ground Ops
rbuxton
Hesperus, CO
I moved recently to a spot very close to Dulles Airport (northern Virginia) and have searched out a few unlisted freqs for airline ground ops. There are a lot of airlines at Dulles that do not have any licensed freqs. Can anyone steer me in the direction of what an airline company might use for a radio system/freq at an airport?
rbuxton
Hesperus, CO
Thanks. I've found the easy ones with license searches and monitoring to confirm them. Even found one in use that is not licensed.
I suppose it's a matter of keep searching and listening for something new.
I'm not sure if the airlines would use a local business system but I'll look there next.
freqhopping
Most likely on the Aeronautical Radio DMR system.
KLM and Air France seem to use the same channel.
Most of the channels are encrypted though occasionally there are clear comms.
majoco
Stirrer
New Zealand
I think you have to distinguish between the ATC tower controlled ground radio where he will direct incoming aircraft to a gate and the company ops who look after the aircraft once it is stationary at the gate - and vice versa when the aircraft departs. ATC will use radio in the 118-136MHz band but companies are liable to use a trunking network either exclusively or with other airlines - refuellers, catering, baggage handling, directions for the passengers may all be on the same network. Never know them to be encrypted, there's nothing secret.
ladn
Have you also considered the use of leased radios? In that case, the license may be in the name of the radio leasing vendor rather than the airline or FBO.
dave3825
Suffolk County NY
You sometimes have to go with what you hear. Some licenses are expired but are still in use. Some do not reflect dmr when in fact they are dmr. Some are leased and to find out about those, it's sometimes easier to search the freq you hear stuff on as opposed to searching the company name or airport name. . You can search here and at http://www.interceptradio.com/fcc.php
Also posting questions in your states forum might help you out as well. And search that airport in your states search function..
ecps92
Taxachusetts
See what NAC you get on 172.9000 [TSA] if that close to Dulles.
JetWayOps
Banned
Banned
Airside:1/Gate:A
Historically airport landside terminal operations had a group of UHF allocated frequencies, I can't pin them down but the FCC CFR for Private Land mobile industrial/Business has them listed. Air to ground company frequencies and FBO's are 122.825 MHz, 122.875 MHz, 128.825 MHz to 132.0 MHz and 136.5 MHz to 136.975 MHz. ACARS is mixed in there too. Lately not only airline hub operations but Airport operations pretty much cover the entire RF spectrum in analog and in various digital modes including "E". The dreaded 8.33 khz step size assignments are alive and well now also. 99% of this is covered in the Wiki and various State databases. Good luck and take care.
