Airport iDEN?
CDS-INC
Banned
I was looking at various states airport operations, and i noticed that most major US Airports have private iDEN systems installed in the terminals.
What do they use these systems for?
Just wondering
John
shaft
Wentzville, Mo
Not sure where he got his info from, but there is a company called ARINC that owns private iDEN systems that are used at some airport facilities for various airport operations.
D
DaveNF2G
Guest
I'm not sure how one would discover that "most major US airports" have any particular type of system "installed." The FCC does not list the type of system, only the frequencies, heights and locations of transmitter sites, basic emission mode and bandwidth, and authorized power levels, and the radio service under which the transmitter is licensed.
I am familiar with several "major" airports and not one of them has an iDEN system installed.
AlexC
I'm guessing you've never flown out of Newark then.
-Alex
ecps92
Taxachusetts
Not all Arinc systems are 800 IDEN
Boston = Analog Trunk
Nantucket = Analog Trunk
ecps92
Taxachusetts
Which Airports then, as Nantucket and Boston are analog and everyone I've seen is Analog not IDEN
Just wondering
John
ecps92
Taxachusetts
All you posted was Arincs web site. Please be specific as to which facilities as Arinc's operations in Boston and Nantucket and pretty much others I've monitored are all Analog.
trainman111
Richmond, VA
Well, I took it upon myself to look up different airports across the country to find out how many were using iDEN systems licensed under ARINC. Needless to say, I found a lot ofmajor airports using iDEN systems as well as smaller airports. Here's a list of them. (I'll even attach links so you won't have to do all the research yourself that I just did)
Kennedy Int'l
http://www.radioreference.com/apps/db/?sid=2475
Newark Int'l
http://www.radioreference.com/apps/db/?sid=2484
Baltimore-Washington Int'l
http://www.radioreference.com/apps/db/?sid=5354
Chicago O'Hare Int'l
http://www.radioreference.com/apps/db/?sid=5740
Chicago Midway Int'l
http://www.radioreference.com/apps/db/?sid=4875
San Francisco Int'l
http://www.radioreference.com/apps/db/?sid=353
Cleveland Hopkins
http://www.radioreference.com/apps/db/?sid=2108
Cincinnati Municipal
http://www.radioreference.com/apps/db/?sid=2126
Columbus Southwest
http://www.radioreference.com/apps/db/?sid=2129
Hilo Int'l
http://www.radioreference.com/apps/db/?sid=5688
Kaehole-Kona Int'l
http://www.radioreference.com/apps/db/?sid=5689
And the list goes on and on...
