Airspy Warranty Info
millam
Old Radio Guy
Anyone had an Airspy (R2) go back for a warranty check? Mine was dead this morning and
all they tell me is questions about if it is seen by the computer and the model number of the
amp that I am using. They want $50 + $10 shipping to SEE if it has user damage and then they
will repair it and refund me $60 if it has been damaged by me. Does this sound normal? Also
will the airspy have to back to China or where ever it was built for this repair? I have bought stuff
from China that takes almost 2 months to get here, so to get there, be fixed, and back to me may
take a while huh.
Mil
millam
Old Radio Guy
left out "not" damaged by me
cpetraglia
Fairfax, VA
I wondered about how hot my got when doing P25 decoding at 10MSPS. I attached heat sinks to both the larger sides and it keeps it way cooler.
excessive heat is never good.
iMONITOR
Silent Key
S.E. Michigan
Nothing on their website regarding their warranty, so it's impossible to comment if it's normal.
cpetraglia
Fairfax, VA
I did not have much luck with them at all. I could not get a driver to install and we had three or four emails back and fourth which amounted to nothing I had not already tried. I spent a few days finding an acceptable driver myself. It seemed as if the tech support new less that I do. For 200 bucks, they could send a CD and some sort of instructions. Mine was not plug and play and I am still not sure if I am using the best driver. It does work though.
Chuck
Airspy-US
Please look three lines below the price in the main product description on our website for warranty info. The European distributor also has warranty info right below the description. We are not sure if the manufacturer has it on their site or not. Warranty info is very prominent on our website.
Asking if the PC sees anything in Device Manager is a standard first question for diagnosis. It has solved several "dead Airspy" issues at no cost or time loss to the customer.
We will not engage in specific support discussions on this forum other than to suggest that if our repair procedures are not acceptable, you can always send it to the manufacturer for evaluation. Our contract does not require us to handle any repairs or replacements, but we do this as a service to our customers. Except for the S/H, the entire fee is forwarded to the manufacturer along with the damaged unit and a replacement is sent to the customer. The S/H has to cover not only shipping back to the customer, but shipping to the manufacturer as well. What we charge does not cover it all, so we eat some of that cost as well.
Please - if you have any questions on our policies, ask US and do not rely on third parties to interpret them. Our contact information is on our website.
As for drivers, software, and other non-hardware matters, please visit the appropriate support forums. While we try to help our customers as much as possible, we are not as knowledgable about things we did not write and do not distribute.
In brief on the matter of policy, we have reviewed the repair policies of a couple of scanner manufacturers. Whistler specifically states that units may NOT be returned to the distributor but must be sent to the manufacturer. They require a cashiers check or MO accompany the unit in the amount if $55. The final fee may be higher. This may not be specifically for a scanner but is for one of their products. Their website seems to have no scanner-specific repair info. The above info was from a Google search for "Whistler warranty repair" (third link).
Uniden repairs scanners at a cost of $69.95 and the cost must be prepaid. Their site does not specify what payment terms are for non-warranty items, but states that repairs higher than standard repair cost will be quoted. It does not specify if prepayment of the entire amount is required or not.
Those are two electronics manufacturers many on this site will be familiar with. It appears our policies are similar, if not better for the customer. Obviously, this is not a detailed study of their policies, but does show similarities and industry norms.
It is normal for the Airspy to run warm.
Drivers are on the Airspy website.
mancow
N.E. Kansas
Mine runs at full spectrum searching 225-400 24/7 with zero issues. No heat sink needed.
slicerwizard
Toronto, Ontario
Hm, Device Manager says:
Universal Serial Bus Devices
Airspy
Driver Details: C:\WINDOWS\system32\DRIVERS\winusb.sys; Version: 10.0.10586.0
Sounds like something that comes with Windows already.
It seems like a normal Windows computer should be plug 'n play. IIRC, I don't think I had to do anything special, even on an XP machine.
And a CD for a tiny driver and some text? In this day and age? I'm sure you realize that the cost for something like that gets pushed on to all of us customers, so no thank you.
Also no heat issues here - runs a bit warm, but that's it.
cpetraglia
Fairfax, VA
Airspy
So here is my driver issue. This shows me there is something amiss. Mine shows in device manager:
libwdi 6.1.7600.16385. At the time of install I was running Win 10 Pro 64bit clean install. No issues with SDR Play or numerous other dongles, just Airspy. I loaded my driver experimenting with Zadig and it finally started working. I was just pointing out while some are lucky enough to get started 'Plug and Play', I was not. Airspy did not stay with me to solve the problem. I am pretty good around PCs and don't usually have these problems. The driver they provide as an alternate did not work.
cpetraglia
Fairfax, VA
Thank you Slicerwizard. Since you gave me the correct driver, I went through the motions of installing it through device manager and it worked. Took 2 minutes. Why couldn't Airspy tech do that? My point was who ever I was dealing with did not know what to do.
Enough said.
Thanks for that correct driver.
Chuck
millam
Old Radio Guy
Thanks, Airspy.us for your reply. I have never returned anything like this for warranty/repair. By
your comments about other companies I now know that your requirements are likely to met or
exceed the norm. My biggest concern was the time frame. In your comments you said you evaluate
the Airspy and determine if it needs to be sent to the manufacture for repair. In direct communication
with Airspy.us they would not comment / could not comment / did not know the time my Airspy would
be gone. Sorry the thread got hijacked by the driver thing, but I guess someone got help.
Mil
Airspy-US
Enough said.
Chuck
You were pointed to the driver on the website several times. That is the Winusb driver. That is also the driver Windows should have found automatically.
Airspy-US
Mil
That is true that we do not quote turnaround times. Some issues are confirmed within minutes. Some take much longer. That is why we do not make promises on the time it will take when dealing with unknown causes. Guessing on such unknowns is a disservice to the customer.
I apologize we did not make that clear via direct email.
In cases where factory repair is required, we will usually send a replacement unit and deal with the repair as time permits. You will note that our email reply to you specified repair or replacement.
millam
Old Radio Guy
I am getting a better feeling of how you do business. I appreciate your answers to my concerns.
I have all the info I need so consider this thread closed.
Mil
Airspy-US
If we can answer any other questions for you, please contact us via email where we may be able to provide more specific answers.
garys
Central Texas
The warranty provisions were pretty clear to me. I wasn't aware that the unit was sent back to China for evaluation, but that's not a big thing. It does explain the time delay of about a month from start to finish.
The only thing (and I haven't mentioned this to Airspy.us yet) is that the unit I received back is consistently about 2.7 Khz off from what SDR# displays. That's not a big deal, but it is a bit of a surprise. I can easily correct that in SDR#, but there is no PPM adjustment in FMPA.
slicerwizard
Toronto, Ontario
A 2.7 kHz error sounds like a big deal to me. At 935 MHz, that's a 3 PPM error. It's defective and should be repaired or replaced.
garys
Central Texas
You know I'm in denial, right? ;)
You're right and I should have contacted them as soon as it came back.
Gary
8K10F1E
Mil
How did everything go in the end?
millam
Old Radio Guy
Good. I received a replacement in about a week and a half. It worked as advertised until a
lightning strike took almost all my electronics in one end of my house. O well!
Mil
