Preamp Sensitivity
Here's a quick example of the preamp sensitivity using the Perseus HFSPAN application. The following shots were taking around 4pm local time from within 1-2 minutes of each other. You can clearly see the 1530S+ amplifier's impact on the lower HF frequencies.
That's not a mistake on the upper HF band. The Wellbrook amplifiers tend to be centered around the lower HF bands. Since most of the HF activity is below 20Mhz, this is a fair compromise. The Pro-1B clearly scores a win here if you're seeking upper HF band performance.
It appears that the 1530S+ preamp is getting slightly overloaded from the AM broadcast stations. This is typical during the day. At night, a lot of AM stations will crank down their power. This is true for our area.
A FM station at 33.42Mhz was -74dBm versus -92 dBm on the Wellbrook. (This is S9 versus S6.)
Wellbrook 1530S+
Wellbrook 330 (this preamp unit has built-in LW/MW attenuator)
PixelSatRadio Pro-1B
Wellbrook 1530S+
