However i did get Pharr pd but i dont understand it how that works sometimes i get them and sometimes theres static or just noice is that normal or is there something i am not doing right.
another thing dont know if i should start another thread for this. how do i use the trunking system on my pro-97. how i have it is i have input all the frequency into every channel. now on trunking do you put all the frequencies into one channel or what??
Thank you very much.
You prolly didn't program it right.
You don't use the Trunking System, you have to enter/program it into your Pro-97.
How can you put all the frequencies in 'one' channel?
You prolly mean 'Bank'.
That depends on the type of system it is. Most of the MOT trunking systems you will only have to enter the CC (Control Channel), on EDACS Systems such as Pharrs you would have to enter ALL the Frequencies and in CORRECT order starting in Chan 01 in whatever bank.you decide to use.
You can take a look at the
Easier to Read Pro-97 Manual this might be a bit more helpful, in explaining trunking and trunking programming to you.
