Albany City Trunk Type..?
EmpireSound
On nf2g.com the type is listed as IIi What does this mean?
-Thanks
mciupa
Canadian DB Admin
Moderator
I'm here a lot
IIi means that it is a hybrid system. So it will have a combination
of Type I and Type II user ID's.
You will be required to select a Fleet Map ,most newer radios have
16 or so preset in them, although this system looks like you will have to
make a custom map and put the size codes in the appropriate
blocks.
D
DaveNF2G
Guest
IIi means that it's IIi. Type IIi means Type II radios operating under a Type I fleetmap.
Hybrid means that some blocks are Type I and some are Type II. That is not the way the Albany systems are configured.
BTW, there are TWO trunked systems in the City of Albany. Most online listings (except my own website at NF2G.com) incorrectly show it as a single system or have some of the wrong frequencies assigned to each one.
EmpireSound
Yes I mean Albany, NY. So if you wanted to trunk this system on one bank what's the Trunk type you would enter it into on a BC250D? CC seem to be 858.2125 for the whole system.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Motorola Type I and enter the fleet map with proper "S" codes (obtained
from Albany system site) in the appropriate blocks.
