The front cable was actually a serial cable but the scanner end was odd. Many called it a Hi-Rose connector but I think that is actually a company.
It was used as a USB connector in some old digital cameras and even digital binoculars.
There was a guy selling real short ones on eBay for under a buck each. One end had the scanner matching connector and the other end plugged into a computers USB jack. So you had to cut that off and figure out the wiring and wire it up to a DB9 serial port connector.
I also lost my original cable for the front port as I never used it. Probably in a junk drawer somewhere.
Then I needed to do a firmware update which can only be done via the front port so I built a cable. Worked fine but I also lost it!
I later mounted a rear port on all my 996 models that was wired to the front port. That way I could leave it hooked up and had no cable to snap off from it sticking out plus I could use both rear ports for logging and programming at the same time. Well, logging I could do at the same time but programming could only be done with one or the other port.
Be careful and I hope whatever you try fixes the LED!
Uniden started using hot glue to try and keep the ribbon cable from falling out over time. I don't recall what model that problem surfaced in but almost every one I've opened, I found the hot glue had came unglued from either the cable or the connector and was not doing anything.
They still use hot glue to this day but they changed the type as it now seems to stay glued to both surfaces. One can still pop it off with a dental pick or tiny screwdriver so you can work on the radio though.
That's better than that darn epoxy the FCC made the manufacturers cover the band switching components with so you could not tune cellular images from the old AMPS band. That epoxy can make repairs to the RF section darn near impossible.
Im thinking ill tell myself its a power on/led indicator!
In a way.Im at least to degree relieved that there is an answer anyway..
I think Ill open it up, the tx is my truck radio,pulled it to program it
( lost the front cable,had to the rear rs232 to update data)
so now its out maybe ill take a peek..those flush/low-profile conns can
indeed just....come unseated..seen it myself with a 2 PSR800s for the
display ribbon...once reseated...Skookum!
must be those tiny scanner fleas at work..
ill dig in..and report back
