Alert//silent mode
CSFD390
Seneca, SC
Got a request to set up a "Silent, or Alert only" channel in a few different radios, and in all of their CPS, the option to do so, gives AND, OR. Which do I need to select for the channel to remain silent until properly activated?
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
AND is for silent. OR is for normal squelch.
Some tips:
Set up a separate personality for your alerting channel even if you also have it as normal channel in another personality.
No scan. When the radio is selected on the alert channel, you should not have any scan active. Don't put the alert personality in any scan list and don't check the autoscan box.
Make sure you assign the QC-II system to the Rx side of your alert channel.
To reset the radio like a pager after an alert, you need one of the programmable buttons to be set up for MONITOR. When the alert channel is selected, the MONITOR button will function the same as the reset button on your pagers.
