Alert Tone
Tahoe610
Westchester County
I am trying to put an alert tone on my UHF 450-512 Radios. Something that i can alert fire fighters on the fire ground of an important message. I would like to set it up on XTS radios and CDM. any suggestions on how to?
evfd1625
Indiana
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.6; en-us; DROID RAZR Build/6.5.1-167_DHD-14_M3-8) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
You could set up a selective call tone using a long a, b, or c tone of a higher frequency. Then send it the call function of the radio.
KC2JS
NJ
You can set up the XTS to put out a hi/low alert while you key up the radio and press the orange top button. I have this in my XTS5000, not sure if it works in other model XTS. This setting is in Radio Wide -> Advanced -> Evacuation Tone.
As far as the CDMs, I guess a 1000 hz long quick call tone could be used. In my department I set up mdc groups so command can alert all the radios for evacuations using a long press on P4 then keying the radio.
Devilz311
NJ
This does work in the XTS2500 as well.
Tahoe610
Westchester County
Cdm
Great thank you all. XTS units working great. having a problem with my CDM and the alert Tone, no such thing as an evacaution tone?
Thank you
Noah
KC2JS
NJ
The only way I can think of setting up an alert tone in a CDM is to create a Quik-Call Call member setting the format to Long Tone and the tone to 1000 Hz. Then you can program a button to Call Alert Member #x. The user would then press the button and key the radio to transmit the alert tone.
jblizzards
It can be done with XTS2500 as well, i have that option working on that model of radios right now.
