All Hanover Co. trs frequencies?
W4UVV
Prince George, Virginia--Central Va.
Does anyone know why the RR database lists only 10 of the 12 frequencies licensed for the trs? (WNSM906) 860.4625 mhz. and 860.7125 mhz. are licensed but not shown in the EDACS LCN assignment configuration.
A wildcard global search of the FCC website shows WNSM906 to be the latest license for their "YE" trs operation.
Stick0413
Hopewell, VA
I'm not sure but it happens sometimes where they are licensed for a freq and never use it (e.g. Hopewell has one).
LEH
Yorktown, Virginia
Another thing to consider is the system is EDACS. For one reason or another they may not be using those two frequencies in their LCN configuration.
If you are not able to follow a conversation on a trunk group ID, then maybe they need to be there, but if the system is working properly, then where in the LCN assignment would you place the two 'unused' frequencies?
They could also be simplex or non trunked repeated talk around channels. If that is the case, then if you can verify their use, report them for inclusion into the RRDB as such.
jehm1212
Hanover County, VA
Those two frequencies were recently taken out of use due to rebanding. LCN's 9 and 10 are now 857.1375 and 858.1375, respectively, whereas before they were 860.4625 and 860.7125.
johndeerefan
callao va
hanover help
i live in tappahannock va and i can pick up hanover but when i put in the trunking code i t wont work i have a pro-433 from radio shack
