All my CP200D questions.
gigaflex
Possible to program a CP200D using MotoTRBO CPS or does it need a seperate software
fwradio
Texas DB Admin
Fort Worth, Texas
It uses the TRBO CPS. You will need a USB cable that will plug directly into the side of the radio. It does not use the RIB and CP200 (old) cable. The USB goes directly from the computer to the radio.
N1GTL
CT
Also, software version will depend on firmware in the radio.
gigaflex
So the CP200 and the CP200D use the same software for programming?
wb1ccp
Lebanon, CT
The radio has a little rubber flap on the lower right-hand side that you have to kind of flip out at the top to expose a micro-USB connector. Most any micro-USB data cable should work, you don't need anything fancy.
gigaflex
Yes i have the cable. The Radio Connects to the computer and gives the connection tone. But I have the MotoTrbo CPS programming software but the software wont recognize the radio. I dont know if maybe i have the wrong software or what.
ramal121
Lots and lots of watts
Calif Whine Country
Mototrbo CPS will program the CP200D. For the CP200, you'd use a completely different software package and a specific cable with a RIB or a ribless cable.
K2NEC
5F6
Try this:
With the radio off, insert the programming cable into the side
Power on the radio
The radio and computer should both recognize the connection
Try to read the radio
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
try disconnecting from your home network, then try reading the radio.
gigaflex
OK so i got the radio to connect to the software but when i try to click recover it says Error 1057 region not supported. I know some people can hack it to disable the region lock but i cant figure out how to do that.
K2NEC
5F6
What is the model number?
alcahuete
Southern California
To piggyback on this question, since we're talking about firmware and programming, what firmware is used on the digital side of this radio? Is it just the standard Mototrbo firmware for portable radios? I have a few I'm working on upgrading, but I can't find specific firmware in my Moto account for the 200d.
gigaflex
Quick question. Is there a reason my mototrbo doesnt have a 200d sample .ctb file? I read that i may be able to bypass the passcode on my radio by straight writing to the radio a new set of channels. But the program doesnt have a .ctb file for the 200d.
Floridarailfanning
Tennessee
In MOL go under the Resource Center then:
Software
Two-Way
MOTOTRBO
Conventional - Firmware
There is R2.7.1 Digital firmware for CM200/300d and CP200d.
Floridarailfanning
Tennessee
If your seeing the 1057 Region Error your not going to be able to program the radio even if you have a sample codeplug. You must have the correct region CPS for the radio model you're trying to program.
gigaflex
where can i download thew correct one from? My model number is AAH01QDC9JA2AN
