What software are you trying to program with? This is a US radio
The only software that lets you program the CP200D is MotoTrbo. I have mototrbo but its saying reqion not supported.
Evidently you don't have the correct version of Mototrbo™ CPS. What part of the world are you in? If you're in the U.S. or Canada then you will need to contact Motorola and find out why they sold you the wrong region CPS. You shouldn't see that error unless there is a mismatch between the radio or CPS region.The only software you can program the CP200D with is MOTOTRBO which i have. But whenever i try to read or write to the radio, i get the Region unsupported error
Im in the US. And i didnt purchase the software. My buddy gve it to me. He also has a couple cp200d's.
Well, then your buddy has the wrong version of CPS too.
In MOL go under the Resource Center then:SoftwareTwo-WayMOTOTRBOConventional - Firmware
There is R2.7.1 Digital firmware for CM200/300d and CP200d.
Theres no site where i can download it for free? Or would i be able to perform the Region hack on this version?
Thanks! I'll give Mother /\/\ a call. It's not showing up there for some reason. Only thing I see is my other firmware for XPRs.
You need to purchase it from Motorola. It's roughly $300 for a 3 year subscription. You can attempt to perform a region hack. Good luck! What region are you going to change it to, if you have no idea what region you're actually dealing with right now?
I searched Mototrbo CPS 15.5 and the first thing that came up on google is a download link to the EMEA version of the software. If this is what you downloaded (I'm not pointing fingers here) then this is the wrong software and you need to get the actual legit software from Motorola. Motorola part number is HKVN4362 and it's $169. You don't need to do any region hack for that CPS because it's the right version of software.If im not mistaken, "AA" is the region code for North America so i would have to change it to that. But i have no clue how to perform the region hack on this version. Im running version 15.5
You installed firmware equal to or newer than what is in the radio? TT
No. A Friend of minbe gave me the mototrbo software. I have mototrbo cps version 16.0 build 828Log in to your MOL account and download it. You have MOL right? TT
That issue typically results in Error 1687.It is showing a region error because your software is likely too old for the last time the radio was written. TT
This is NOT the way you should be going about this. If you insist on using illegally obtained, illegitimate software this is not the forum to be discussing it on.Is there any place else i can download the firmware?
