All my RX path questions
Bonkk083
Union, SC
It might. Depends on the exact antenna. Not all cellular companies use the 800MHz band.
Won't hurt your radio to plug it in and give it a try.
I saw this antenna
I am a lineman for the county.
I saw this antenna
Unless you need the 1710-2700 frequency range, you'd do better with a single band antenna.
Bonkk083
Union, SC
I just need 698-960, I might have a problem with a directional if I point it to the northwest would it pickup a site to the the east about 30 miles
Bonkk083
Union, SC
if i got it right you want 851 to 862 as that would be the '800' band.
I saw one that was 851 to 869, but another site uses 773 mhz I don't see how that can Pametto 800 when some sites are in the 700s confusing
Bonkk083
Union, SC
wtp
Port Charlotte FL
ok, so the two sites in your county are simulcast.
i would go the other way and get a radio that receives well on simulcast.
my county is on 700 and simulcast and we would actually get half a second and then nothing for half a second.
then we got a uniden SDS100 and now hear everything.
so if you could check out that site for the system and then get back to us, thanks.
Bonkk083
Union, SC
wtp
Port Charlotte FL
also after reading that you get 1 to 2 bars and the radio won't decode, that is a sign of simulcast and more antenna will make it worse.
just like they have said. it would be best to ride to the towers and make sure you have things right and then try to figure out why you can't hear them. also many system point their antennas down now to avoid interference with other systems. so you might not get some with anything you buy. when i drive out of my county the signal disappears within 1 mile of the border.
Bonkk083
Union, SC
What does the green highlight means
Bonkk083
Union, SC
Will a yagi pickup sites 20 miles or less in different direction if it's aimed in another direction
dave3825
Suffolk County NY
Generally it can if its tuned for the freqs. I use one from Eastern Long Island into Manhattan with an LNA. Tho I want to build another with thicker elements.
